Old 03-29-2009, 11:58 AM   #3 (permalink)
Westrock
Haxord but mine
Westrock's Avatar
In Step 8 on the instructions it shows using the aluminum bungs to cap the cooling hoses under the intake manifold.
Is this required or optional? It looks like it will clear everything, and I'd rather not mess with the cooling system if not required. I dont plan on eliminating the coolant loop through the throttle body, so I dont see where this kit would effect anything with the cooling system.
UPDATE: This step is not required. The hose actually just makes a loop that is ziptied to oil lines below. You can cut the zip tie and reposition this loop if you dont wish to mess with the coolant system.
-David
2006 Storm Ti Exige + VF Stage 2
Vision Function Supercharger Install Thread
Stereo Harness Info | Exige with no wing??
Westrock is offline   Reply With Quote
