Old 03-30-2009, 08:16 AM   #18 (permalink)
antinym
The Doombringer
antinym's Avatar
yeah, the instructions on that Vvti are vague at best.
The part of the solenoid in the block can rotate independently of the part with the electrical connector. You need to make sure the part in the block lines up the way it did before you put the adapter on. If you don't line it up the same, you won't have the second cam (ask me how I know) Make your marks, bend the little tabs, rotate the solenoid body, bent the tabs back and install. Don't break it, that's a $250 part.
antinym is offline   Reply With Quote
