Old 04-02-2009, 07:32 PM   #1 (permalink)
TheViper
Alarmed & Dangerous
TheViper's Avatar
Remote Key Fob & Immobilizer Programming
Now Available; Alarm/Immobilizer/CDL Emergency Overide
APPLIES TO 2005 - 2007 ELISE / EXIGE USING COBRA 8186
It frequently is asked how to "re-sync"or "program" the remote key fobs into the alarm system, so here it is. Additionally, I thought it would be useful to post on how to program the alarm so that the immobilizer will not "passively" (automatically) arm, but instead, only arm "actively", by using the remote key fob.
Note: The alarm & the immobilizer are two separate, but connected components, and the alarm is already programmed for "active" arming.
BEFORE ATTEMPTING ANY PROGRAMMING I RECOMMEND BECOMING VERY FAMILIAR WITH THE PROCEDURE & SEQUENCE BY READING THE INSTRUCTIONS THROUGHLY
PROGRAM FOR IMMOBILIZER "ACTIVE" ARMING
USE WHEN YOU DON'T WANT THE IMMOBILIZER TO ARM AUTOMATICALLY
STEP 1 – ENTER PIN NUMBER
1) Turn ignition ON and OFF 3 times within 5 seconds.
2) Tachometer security LED will blink once indicating that the security code can now be entered.
3) Enter security code as follows:
....a) Turn ignition ON & count number of blinks representing 1st digit of code then turn ignition OFF.
....b) Repeat for 2nd digit.
....c) Repeat for 3rd digit.
....d) Repeat for 4th digit.
4) Turn ignition ON and security LED will come on permanently if correct code has been entered
STEP 2 – ENTER MODE TABLE *
Press large remote button “A” for 5 seconds, security LED will go OFF & give one long flash indicating now in the MODE table.
STEP 3 – ENTER FUNCTION TABLE *
Turn ignition OFF then ON, security LED will go out and then flash twice indicating now in FUNCTION table.
Each time button “A” is pressed it changes from A to N indicated by corresponding 1 to 12 blinks.
Program to “N” 12 Blinks - Immobilizer passive arm "OFF" Alarm passive arm "OFF"
Press button “B” to confirm selection
Alarm & Immobilizer will only become active if the large remote button is pressed
STEP 4 - Turn ignition off to leave & save programming
* In either MODE or FUNCTION tables.
Slow blinking of a MODE (A – H) or FUNCTION (A – N) indicates that this is the programmed selection.
Default on the Lotus is Function "F", 6 blinks.
REMOTE KEY FOB - RESYNCHRONIZATION - USE WHEN EXISTING REMOTE CEASES TO WORK
1) Remove battery & wait 10 seconds before re-installing (re-sync can fail if this step is missed)
2) Hold down both buttons (LED will light) for approx.10 seconds until LED turns off.
3) Release both buttons and LED will turn on constantly.
4) Press large button for one second, LED will flash…re-sync. complete
REMOTE KEY FOB - PROGRAMMING - USE WHEN ADDING A NEW REMOTE INTO THE SYSTEM
IGNITION MUST BE ON AND THE ALARM OFF
STEP 1 – PREPARING ALL REMOTE KEY FOBS - ALL FOBS MUST BE DONE SIMULTANEOUSLY
Press and hold both buttons on remote until the LED stops flashing (about 10 seconds).
Do this for all remotes to be programmed
The LED on the remote should stay on until after programming.
STEP 2 – ENTER PIN
2) Security LED will blink once indicating that the security code can now be entered.
.... a) Turn ignition ON & count number of blinks representing 1ST digit of code then turn ignition OFF.
.... b) Repeat for 2nd digit.
.... c) Repeat for 3rd digit.
.... d) Repeat for 4th digit.
4) Turn ignition ON and LED will come on permanently if correct code has been entered
STEP 3 – COMPLETE THE REMOTE KEY FOB PROCEDURE
1) Press and hold the large button on one of the remotes until the security LED light in the tachometer goes out then comes back on.
2) Do this for each remaining remote
3) Turn off the ignition and check each remote for the correct operation.
DISARMING ALARM/IMMOBILIZER USING PIN
Alarm/immobilizer will disarm if the correct PIN has been entered
