Dip Stick
The projection of the dip stick using the OEM dip stick tube is 173 mm.
I had to shorten the tube that was originally supplied by 39 mm to get the same projection. Jermaine now supplies a shorter tube which I believe to be the same. I also increased the bend in the tube by roughly 10 degrees so that it ended up against nearer the engine and away from the firewall.
