Originally Posted by turbophil
Hmmm.... that hardware looks really familiar
Thanks for the studs and nuts, made it tons easier to get that gasket and manifold on.
Originally Posted by viva
The projection of the dip stick using the OEM dip stick tube is 173 mm.
I had to shorten the tube that was originally supplied by 39 mm to get the same projection. Jermaine now supplies a shorter tube which I believe to be the same. I also increased the bend in the tube by roughly 10 degrees so that it ended up against nearer the engine and away from the firewall.
Now you got me concerned, I didn't even think to measure the dipstick tube length...
