STARTING A RESTORATION
After 30 years of ownership, I'm finally going to start restoration of my 74 TCS #3733R,at the same time I'm going to try and reassemble #3857R that i purchased 2 years ago. I'm sure i'll be here alot to ask for help, suggestions,sources, etc; and hopefull to provide the same if possible! any way I'm going to start the process with a ?, what is the approx. weight of the body work of a TC Europa? The first thing I'm planning on doing is seperating the body from the backbone to make sure there is no rust or damage, powdercoat, and then refresh/replace the suspension. If the body is light enough I'm going to build a "shelf" to stack one body above the other so I can work on both chassis' at once!Thanks in advance for any help or suggestions, and i'll be posting pictures as the project develops!
