Old 04-04-2009, 06:12 PM   #3 (permalink)
dwkoski
dwkoski's Avatar
If the body is COMPLETELY stripped, two men can easily lift it and move it around. As I remember it was under 200# with the doors off. Every thing you leave attached adds to the weight. See my previous post on a thread about S2 restoration a couple of days ago. Take your time disassembling and measure the length, size and thread pitch of EVERY bolt you remove and log them carefully. Europa uses SAE AND Metric fasteners so keep everything organized. when the body is off the frame, it should be stripped to bare glass, preferabley by plastic bead blasting, You won't believe how many voids, air pockets and cracks you will find as the original bodies were not that well made. Assuming you are doing a correct and quality restoration, you need to grind out and fill all the voids and then apply a new coat of gelcoat. Then comes all the block sanding, priming, sading, repriming...until it's right. Be sure you remove ALL the window glass before stripping. The frame should be inspected and if it is seriously corroded, new ones are available from the UK. If not the suspension can be disassembled (frone A arm bolts may require heat from a torch). Sand blast and epoxy or powder coat (I prefer epoxy but that's just me.) Same with suspension components and replace all bushings. Engine and trans rebuild probably contact out (although relatively straightforward if you have engine building experience.) Same with interior. I did mine 13 years ago, did almost all of the work myself, started with a car in very good original condition and still had 12 grand in parts and services in it...be warned...Dave
dwkoski is offline   Reply With Quote
