Old 04-05-2009, 08:22 PM   #36 (permalink)
shay2nak
I <3 chicken, I <3 liver
shay2nak's Avatar
FYI, my OBDII reader displays IAT and i was between 90 and 104 out driving in the canyons in about 75* weather today.
Originally Posted by HKFEVER View Post
I am looking to custom make a frame inside the plastic hood to house 2 push fans.
And 4 to 6 parts CF heat shield with gold plated bottom to seperate the intercooler from the rest (funny ideafrom the PS).
Looks like that whole section is blocked off. Do you have the side intakes blocked, too? You want those open to feed cool air into engine bay.
Originally Posted by ads_green View Post
I can see where you're going with the heatshield but I would expect adding the CF heat barrier between the IC and the engine would affect the cooling to the engine. The mesh on the back is the primary exit vent for the engine cooling airflow as air is taken in through the VRIS vents on the floor and the sidepods and out through the engine cover.
Fundamentally the IC is mounted in less than ideal position and airflow to the engine bay is not great to begin with.
The heatshield would be slightly larger than the intercooler's footprint and slightly raised front and back. It won't block any airflow. all the heat is coming from beneath the IC.
'08 ACURA TSX 6-speed
http://www.makeNYNYagain.com
