Man yours look much better. I have all mine on the inside and its makes getting to the bottom coupling a little tedious. I did think about going through that front opening under the IC like that. I might redo mine, just have to stretch those babies.
I have had to notch the manifold and the VVT adaptor to clear each other. Just a hair on both.
And I did shave and notch the intake manifold so that a DBW throttle body can just mount right up and not need either adaptor. Did you end up actually using that little vacuum nipple on the side, or can I just plug that?
