Old 04-20-2009, 01:46 PM   #22 (permalink)
robains
2007 Exige S
robains's Avatar
As per my other engine thread. I'll add my compression test results to this one:
190 - 185 - 180 - 190
This is with Mahle 9:1 pistons.
Also noted that with all plugs OUT, throttle open/closed made no difference in the readings. Clutch in/out also made no difference.
I think what could cause the biggest variance in readings is how well one secures the compression tube in the spark plug hole. Small dab of oil on the rubber seal is pretty good at ensuring a good seal and more accurate readings.
5 or 6 cranks worked well for me.
Rob.
