Old 04-20-2009, 01:53 PM   #11 (permalink)
Demonized
NOT ßANNED!
Demonized's Avatar
Originally Posted by Cthulhu View Post
I'm registering on those forums. I may also call vision function and ask some more stupid questions to figure out what the buy first, lol. I definitely need some clarification of ECU/EFI stuff, and where and what to start programming first.
Is it most cost effective to get Charlie to flash my ECU? Will I need another reflash if I mess with EFI stuff or my pulley? How much would it cost to reflash myself (raw materials needed to interface, including any applicable software). I'd rather set everything up for PC modification (I think i will have to, eventually)
I have never used a standalone electronic fuel injection management system, but i imagine that it would have to run in conjunction with the ecu, as in the ECU has to keep the dash running, and take measurements from sensors.
If you mess with the pulley you will need another tune, not sure what charlies policy is on that though.
YOU WILL NOT be able to get the software to write your own program to the ECU unless you make it yourself. EFI systems can be used with a PC with the software for them.
(I tried to mess with that stuff on my Merkur, and I basically blew it the **** up. Which is not uncommon. )
