Old 04-20-2009, 05:59 PM   #25 (permalink)
goldengatehornet
British Car Restoration
goldengatehornet's Avatar
Originally Posted by robains View Post
Also, if the motor is too hot, it will tend to melt the compression testors rubber seal unless your compression tester doesn't use rubber seals and is of the type that can be torqued down.
A Viton O-ring is good for over 200 degrees C. A Teflon one is good for over 500. On my race car, I start with a hotter plug, warm the engine to temp, then change to the colder plug for the track. This eliminates the problems of fuel fouling. This is a common practice. Antisieze on the plug threads is good for even street engines.
P.S. work hard in Cupertino. I need my Apple stock back up to $150. Typed on my Powerbook, as my HP is half the speed.
goldengatehornet is offline   Reply With Quote
