Old 04-21-2009, 01:26 PM   #4 (permalink)
apk919
ΒÄŅNED
apk919's Avatar
Images: 20
Originally Posted by gpheck View Post
Brake and reverse lights dont work after pulling them off and putting back on!!
Long story short... I pulled off my 4 back tail lights and completely took my dash off and removed passenger airbag.
Haven't put the dash back together yet, but plugged in the ignition panel - with the headlights and ignition switch and running lights etc. and put the tail lights back in so I could drive/move the car.
Now my brake lights and reverse lights dont work. But the brake lightbar works when I press the brake pedal (just not the back led tail lights), The headlights work, the turn signal works, the running lights work (sidemarkers work when signals are on etc etc)
I checked fuses they are all good. I switched the tail lights around to make sure they weren't put back in reversed. I checked the ignition panel to make sure i didnt switch those wires around. I plugged in the hazard switch on shifter column.
I don't know what else could be wrong I'm at a loss. The tail lights were unmodified unopened etc. nothing was changed with those.
Ideas please anyone!!
sm450r@gmail.com
Thanks, Graham
OK, I'm assuming Federal Elise/Exige, 2006+
According to the manual, the connectors that go to the brake/reverse lights are labeled "RIHC" & "LIHC" (right inner harness connector and left inner harness connector). The high-mounted taillight is connected directly into the brake light circuit through wires only... so if that's working, I'd check your connectors to see if they're firmly seated...
