Old 04-21-2009, 06:30 PM   #7 (permalink)
turbophil
Plug Whisperer
turbophil's Avatar
Images: 6
I've got the EFI pinout at the shop... Can't recall off the top of my head which wire you connect the WB 02 to... Once we get that item sorted, there are a couple items to change in your map so that you reference the WB 02 and run it on closed loop opposed to the narrow band you were running... Back to you before too long
...Unless somebody else gets to you first!
Speaking of somebody else, Dave has the breakpoints and setpoints for the AEM... Dave, you reading this? If not, I've got those at the shop too
Best,
Phil
