Old 04-25-2009, 06:47 PM   #12 (permalink)
Kris from DRS
Dynamic Racing Solutions
Chris
I sent you an email w/ this info, but I guess it never made it to you.
You need to swap the Lambda signal pin from 5 of 26 (the smaller connector of the two) to 31 of 34. Then in the software set the Lambda Control from 1 to 2. Then in Data Controls you will reference Lambda 2, but still use Lambda Cor 1 for the correction %.
The harness I sent you has the connector to mate to the old Lambda 4 pos connector and a single wire on the opposite side. This is the wire that connects to the 0-5V output on the AEM module.
See calibration below for AEM Lambda meter: Copy / paste this into the Lambda 2 calibration.
Calibration for AEM Lambda
Breakpoint Sensor Cal
0 / 0.685
52 / 0.72
108 / 0.755
160 / 0.79
216 / 0.83
268 / 0.865
324 / 0.9
376 / 0.935
428 / 0.97
484 / 1.005
536 / 1.045
592 / 1.08
644 / 1.115
696 / 1.15
752 / 1.185
804 / 1.22
860 / 1.26
912 / 1.295
968 / 1.33
1020 / 1.365
Motorsport Components and Expert Service. Complete Lotus maintenance, installations, track preparation and specialty services.
Kris from DRS is offline   Reply With Quote
