The Braille 106 does not have a disconnect relay. Braille do make an auto-disconnect, called the "power protector", it has a yellow cylindrical top to it, check if you have it. If the battery was disconnected the alarm would switch over to it's back up battery and sound.
Cheers, Michael
Originally Posted by Cthulhu
I just got my Braille 106 battery (6.6 lbs). I use my exige as a daily driver and needed a replacement for my big, exhausted 40 lb marine battery (prior owner's selection). The specs on the battery made me a little cautious... 10 amp hours... I had fabricated a stock battery bracket (it was nice, looked IDENTICAL to the original), but then found my OEM bracket under the carpeting in my trunk. So, I sawed some grooves in the bracket I made so that I could bend part of it around the smaller battery. I also used a few additional washers, a zip tie, and double sided sticky tape to mount the battery, and banged my aluminum bracket down a little to widen it. The bracket clamps against the side of the battery nice and hard and it weights 7 lbs, so it isn't going anywhere. I have enough scrap metal to fabricate a better bracket if I needed.
I expected this 10 amp hour battery to be "smart", by which I mean: include some type of trickle drain prevention so that my alarm doesn't kill it. I'm assuming this protection exists because every time I turn my car off and leave it for a few minutes, my clock resets to some random time of day.
I may call up Braille and find out if there's a relay inside the battery that opens in certain situations. If there is, then I'll put a tiny 12-14V battery (like a 1AH 12V battery pack) in parallel with the main battery.
If there is a relay, I HOPE someone at Braille knows if I can use a small parallel battery to keep the clock alive. If the Braille battery has a relay, maybe it won't open if it's equillibrating with another parallel battery. Any thoughts before I harass Braille?
