Originally Posted by 38bfast
We logged oil pressure and it is downright scary without the Acusump. PSI dropped down to 18lbs in several spots on the track. Even with the Acusump PSI dropped to 28lbs. Seems quick transitions are hard for the stock pan to manage. Again T2 rules mandates we use the stock oil pan.
Did you try overfilling the oil level? What pressure are you using in the accumsump? Did you use the non return valve for the accumsump?
