Traqmate Controller location
Originally Posted by Lotus-Position
Hey CL: Looks great! Since I plan to mount the TM controller within reach, I was thinking I would mount my Chasecam/TM "CPUs" on the floor of passenger side next to the center brace. Would love to know where/how your installer tapped for power and RPM... can you provide a pic of each? Were they able to spade-connect for power under the dash? RPM off the coil?
Power comes from 12V power outlet between seats and the RMP is off the coil. I bought a panavise stay-put flex mount (12 inch rise) to mount on floor (passenger side) for the TM controller and then decided I didn't like the location of the possible install (although I might change my mind). Where I put it is clean, only problem (as mentioned before) is that the display is not visible while driving on the track. I can reach the controller with 5 point harness (just barely) to start and stop.
'07 Exige S,LSD,2bular Header,SportCat & GT3 Exhaust,Gotham Tune ECU, V2 Fuel Cell,BOE Surge Tank,MWR Fuel Rail,RLS Intercooler&Pipes,CircuitWorx Oil Pump Gears,Moroso oil pan, Accusump,Fidanza 3.2 Kevlar Clutch & Alum Flywheel,Nitron GT3,V2arms,AP Racing Brakes(315mm),SS Brake Lines,Prototype Composites CF Roof,ReVerie CF Front Splitter,diffuser & 1650MM Wing,RTD Brace, SSC Shift Cable, Lotus Racing M Mounts/High Perf.Air Box,Defi Gauges,RAC Monolite Wheels,Safecraft 5 Point Harness,Traqmate.
