Here is the setup I ended up with. Haven't used it on track yet, but I expect it will work great. I especially like where the Chasecam PDR100 ended up... it will be easy to operate the menu system and insert/remove flash cards from that position. Everything is velcro.
Not shown is the Traqmate control unit. I plan to velcro that to the driver-side visor, routing the wire across the ceiling (using gaffers tape) and down to the traqmate control unit.
Not sure where the GPS antennae goes yet. On my SRF, it sat on the frame under the front clip (also fiberglass) and worked fine, so I plan to try keeping it inside the cabin somewhere.
The MSD seems to work great in the position shown in the photo. I routed it via the shifter cables "center tunnel" (the blue wire next to the white power connector).
Tapped the aux power output (white connector) to power the MSD, Traqmate, and Chasecam. Just got to remember to shut everything off via the control unit so I don't burn up the battery since the aux power is not switched.
