Originally Posted by Chili Red
Lotus-Position your traqmate is facing the wrong direction..  I assume your just flipping the Axis for the g-forces?
Correct... I verified with Glenn at Traqmate that the accelerometers are just as sensitive in this direction. As you indicate, I'll flip it in the software. You just have to make sure you position it at some multiple of 90 degrees. Not sure if this will cause issues with exported data though... guess I'll find out. It's all velcro, so easy to re-orient if need be.
