Old 05-09-2009, 11:52 AM   #62 (permalink)
Eyelise
Eyelise's Avatar
I did remove the 10mm bolt and rotate the valve. It still doesn't seem to have the clearance. Maybe I'll just remove the oil return line and valve.
Originally Posted by robains View Post
remove the 10mm bolt holding VVT in and rotate VVT, this should give you enough clearance to remove intake.
Eyelise is offline   Reply With Quote
