Thoughts on this ECU dump....
I'm looking at a 2006 Elise. The car has approx 4400 miles and has been tracked quite a bit.
Here is the ECU dump data that I recieved from the owner.
Last 0-100kmh - No data
Last 0-160 - No data
Number of Standing starts - No data
Max RPM 1 - 9481
Throttle position - 1.5-15% - 92.53
Coolant Temp 3 - 92.29
Coolant Temp 1 - 91.66
Coolant Temp 4 - 91.04
Coolant Temp 5 - 91.04
Coolant Temp 2 - 90.42
Max RPM 2 - 8710
Max RPM 3 - 8700
Max RPM 4 - 8695
Max RPM 5 - 8690
Max RPM Engine hours 2 - 58:40
Engine Speed - 2500-3500 RPM - 49:37
Max RPM Engine Hours 1 - 48:39
Wheel Speed - 0-30kmh - 46.36
Max RPM Engine Hours 5 - 46:33
Max RPM Engine Hours 3 - 45:44
Engine Speed - 4500-5500RPM - 4:41
Engine Speed - 500-1500 RPM - 36:34
Max RPM Engine Hours 4 - 33:14
Wheel Speed - 90 -120kmh - 31:38
Wheel Speed - 120-150kmh - 3:10
Wheel Speed - 60-90 - 27:45
No coolant temp issues.
I'm not entirely sure how to read this data, but the 9481 rpm max in first gear is obviously popping out at me. Seems I should have the owner do a compression/leakdown test? Any other feedback you can provide?
Thanks
