Old 05-11-2009, 10:49 AM   #4 (permalink)
EastCityBoy
EastCityBoy's Avatar
I just removed my under tray today for an oil change and used a similar type of tool. The one I have (had) is a cheap Chinese made piece of junk but it was working well until I tried to undo one of the two 13mm bolts without first loosening them by hand. Bad idea. It stripped the internal gears in the tool. The bolts weren't that tight either. So a word of advice. While I cannot speak on the quality of this particular tool, generally when using this type of tool on larger bolts, I suggest loosening them by hand a bit first.
That said, these are a great for taking off the under tray. No need to even jack up the car. You can take the tray off in five minutes or less.
2007 KG elise
EastCityBoy is offline   Reply With Quote
