Old 05-11-2009, 11:18 AM   #5 (permalink)
TheViper
Alarmed & Dangerous
TheViper's Avatar
That is a great bit of advice, I have had no problem, but hypothetically if a bolt is in really tight it could happen, I don't know. Mind if I reference it?
Cheers,
Originally Posted by EastCityBoy View Post
I just removed my under tray today for an oil change and used a similar type of tool. The one I have (had) is a cheap Chinese made piece of junk but it was working well until I tried to undo one of the two 13mm bolts without first loosening them by hand. Bad idea. It stripped the internal gears in the tool. The bolts weren't that tight either. So a word of advice. While I cannot speak on the quality of this particular tool, generally when using this type of tool on larger bolts, I suggest loosening them by hand a bit first.
That said, these are a great for taking off the under tray. No need to even jack up the car. You can take the tray off in five minutes or less.
