Originally Posted by tesprit
Open the trunk lid/engine cover with your key (yes this will set off the alarm) and gain access to the battery. Attach a 12V source (another battery with jumper cables, jump pack, etc.) and now use your alarm fob to turn off the alarm and open the doors. Once you have the alarm and immobilizer off, recharge or replace your battery with a new one if it will not accept a charge. If you have an Exige, you can access the power posts under the forward access cover with your 12V jump leads and follow the same procedure.
I've found another step necessary - after attaching a 12V source. reset the system. Press both buttons on the fob for at least ten seconds / until the light goes out, release both buttons, and press the big button for 1 second.
I've been in this predicament twice
, and am getting it down to a drill. I have an extra car battery and use that to turn off the alarm and unlock the doors.
