Old 05-17-2009, 06:09 PM   #49 (permalink)
Kris from DRS
Dynamic Racing Solutions
Enrico,
A safety trick to help reduce the chance of a very high idle in the event of a vacuum leak is to set the decel limit to low rpm of ~ 2,000 to 2,500 and set the throttle limit to about + 1-2 degrees of the closed throttle position.
For example, if the engine likes to idle w/ the throttle at 8 degrees, set the decel limit to 9 or 10, this way when the engine is below your set throttle, but above X rpm the injection shuts off. This is a strategy to concerve fuel in deceleration as well.
Kris
Motorsport Components and Expert Service. Complete Lotus maintenance, installations, track preparation and specialty services.
Kris from DRS is offline   Reply With Quote
