Old 05-19-2009, 06:36 PM   #24 (permalink)
vyuen
Originally Posted by TheViper View Post
If you apply 12V from a secondary source to the battery terminals, the alarm should respond to the remote if the fuses are OK.
If the battery you have must not be "jumped" then I would put it on a charger.
As in charge the battery via the external terminals?
But maybe I should check the fuses first. How do I find out which fuse is the one that is linked to the alarm system? I have a feeling its not a fusing issue as when I attempted to jump last night I could see the faint glow of the alarm light in the dash, which wasn't the case before I jumped it. So I'm only guessing the power wasn't sufficient to activate the doors?
vyuen is offline   Reply With Quote
