Originally Posted by Thomasio
A cutoff switch is designed to fit on top of the bracket, on the flat in front of the center lightening hole. I'll post photos later today.
You can buy it here for about $22. Battery Switches
Del City also has the lug that you will need to connect to the Odyssey battery. (Your stock battery has round posts, the Odyssey does not.) I can post part #'s later if you need them.
How about putting together a couple of SKUs:
battery bracket only
bracket + battery+ cable ends
battery only+ cable ends
bracket + switch + cable ends + short return cable
battery+bracket+switch+ cable ends+ short return cable - The Works Kit! (This is what I'd buy)
Make it easy and one stop shopping for us. Thanks
2007 Exige-All Black and Mean
, Factory TouringPak/TrackPak/StarShield/LSD/TractionControl/iPodDock. All stock but not for long.
v = square root ((2 * e) / m)
