Originally Posted by Aedo
Great looking car!
But getting hydrogen from an onboard water tank using electrolysis is just complete rubbish
In english this translates as:
"We take electricty generated by the 25% efficient ICE, use that at ~70% efficiency to liberate hydrogen from water, we add this to the ICE and recover it at about 25% efficiency (so we are now at ~5% of the original energy contained in the petrol) and voila - the car is now vastly more efficient!"
Sorry - but that is the description of perpetual energy.
I think the theory is that you are currently not burning all the gasoline or petrol, because combustion is incomplete. Many of the fumes going out the tail pipe consist of unburned fuel or incompletely burned fuel.
So if you can make the engine burn the existing fuel more completely, you will get more energy from the same amount of fuel. Specifically, the H2GO devide is reducing the amount of energy loss and increasing the efficiency of the conversion of gasoline (petrol) into kinetic energy.
That, as I understand it, is why the device simultaneously increases gas mileage and also reduces polluting emissions. More of the fuel is being consumed in the engine instead of being spewed out the tailpipe as waste.
Obviously they will have to prove performance on the road.
And it is obvious that others have been spewing nonsense like cars that run on water.
I don't know if their theory works.
But at least what the theory is is quite different from what other people have been talking about.
If you think about it, the conversion of gasoline (petrol) energy into forward motion is far more complex than just the raw amount of energy in the fuel.
Energy is released when the gasoline is burned.
However, if you simplly pour the gasoline on an empty field and burn it, you will not get any forward motion (kinetic energy) aside from people running away, perhaps.
To convert the raw energy content of the gasoline into forward motion depends upon the speed with which the gasoline explodes, thus creating a sharp pressure differential between the two sides of the piston.
Rapid combustion (explosion) will drive the piston far more strongly than SLOW combustion. Rapid combustion (explosion) will drive the piston and drive the car. Slow combustion will simply heat the engine block through the metal sides of the chamber.
Point being that there are a lot more factors involved in the process of converting gasoline's chemical energy into moving the car down the road than simply the raw energy content of the fuel.
It may be that there are no improvements possible in any part of that process.
But I don't think we can just assume that no improvements are possible.
I think it was around 1899 that the head of the US Patent Office recommended closing the Patent Office because everything that could be invented had already been invented.
Boy was he wrong.
Don't get me wrong: I'm not telling you to be careless with your money.
My philosophy is to always buy a new product AFTER the 3rd or 4th version is out on the market, after the price has come down, after all the bugs have been worked out, after all the goofs have been discovered. So I am not saying to close your eyes and jump off a cliff. I'm just saying keep an open mind.
