Old 05-31-2009, 10:18 AM   #20 (permalink)
Vulcan Grey
Vulcan Grey's Avatar
Originally Posted by eurosport View Post
Curious. Are you sure there's not an access hole already in the footwell? There is on the G-cars by design, and it's still as much a PITA as it sounds to remove (monkey arms holding wrenches inside and out, or breaker secured on the outside end and wrenching from inside )
Nope, no hole. I'd have to drill one into the foot well. The upper wishbone bolt is also put in the same way, though there is a section of the body that is ground down there, not sure if it has an access hole there off the top of my head. But really no good way to remove the front suspension.
I'm sure on the assembly line it seemed fine, with the body off...
Travis
Vulcan Grey Esprit SE
http://vulcangrey.lotuscolorado.com/gallery
Vulcan Grey is offline   Reply With Quote
