Old 06-03-2009, 05:27 PM   #3 (permalink)
Chris Mackey
Chris Mackey's Avatar
Originally Posted by Simba View Post
For replacing the dash speakers, it's absolutely necessary to remove the upper dash cover if you plan on retaining any kind of sanity (and an unscratched windshield). You'll need four of the special passenger airbag clips to accomplish that, available from Lotus Garage.
I replaced mine without removing the dash. You just need an angled screw driver. It was easy.
Tips/Ideas:
1. Get the Jim Clayton speaker rings available on forum so that you can install 5 1/4 speakers up front - big difference. Not expensive or hard.
2. The dash is easy to remove. It takes about 45 minutes and only requires the aforementioned clips from lotusgarage (or your dealer). I pulled mine in order to install a satellite radio unit and an iPod module, which is accessible by way of the passenger cubby. There is room for a small amp in there, I think.
2006 Elise, Ardent Red, Black Pack, LSS wheels, shocks and springs.
Chris Mackey is offline   Reply With Quote
