Old 06-06-2009, 05:45 PM   #11 (permalink)
Simba
2/3 hp to the paws.
Simba's Avatar
I'll clarify slightly-- you don't need to remove the dash to replace the factory speakers with other speakers of the same size. If you're using the 5-1/4" rings, you most certainly do need to in order to glue them in properly.
Also, it's extremely easy to crack the windshield as was said. Popping the dash cover off is cheap insurance, and it allows you to run your wires in a much cleaner way, assuming you're upgrading them as well.
