Old 06-08-2009, 07:00 AM   #154 (permalink)
Dragon
Hydrocarbons Rule
Dragon's Avatar
Images: 2
Originally Posted by RichardNHCooper View Post
Can anyone explain this. My VF stage ! runs great but if I turn right above 1900 rpm it misfires until I straighten the steering but when I removed the ABS fuse and hence the wheel sensors the problem was resolved. This then returned when I reactivated the ABS. '06 DBW Elise.
One thing to check is that the sensors are magnetic, so metal debris etc can stick to them and some times cause pickup issues.
2nd thing is if you have changed your tires to a slightly smaller diameter rear and slightly larger front it will cause the traction control to kick on during cornering. (If you have that option on your car)
Dragon is offline   Reply With Quote
