Old 06-11-2009, 09:52 AM   #7 (permalink)
sleepe
sleepe's Avatar
When I had my vf2 installed at VF in Maryland, the clutch shop that VF used did not tighten the nut on the driver's side engine mount sufficiently. The nut and bolt subsequently fell off at some point. I only realized this after the engine began surging and making funky noises that sounded off. Your sound seems to be emanating from the sc though.
Check all your bolts, especially if you installed motor mount spacers or s111 mounts.
BTW the bracket that hold the SC nose in place came loose at some point as well. The bolt that connects the sc bracket to the engine iron mount was missing. I only realized this because again, the motor was surging and sounded off. Check everything...
-Robert
Elise'06ST:RAC/r888-Ultradiscs-Larini 8"-Braille-Saikou Michi cans-Nitron sportpro-RTVbrace-widened undertrays-manly's motor inserts-FF engine damper VF2
sleepe is online now   Reply With Quote
