06-13-2009, 07:44 AM
#3 (permalink)
Form and Function
Originally Posted by TheViper
a) Although the turn signal lights are used by the alarm, they are independently fused and controlled also, and should still work for signaling, do they? Check fuses F6 & F9
b) Does the interior light work?
c) Check fuse F11 & R2?
d) Have you done any work on the car?
Hi Michael, thanks for the reply....
There has been a lot of work done on the car...turn signal delete with rewiring of DRL's....LED light upgrades with rewiring...
My car is at the body shop, so I can't check fuses just yet, but I'll do so as soon as I get it back - are those fuses in the front (under right access panel?) or in the rear?
www.FaceNBody.com
2005 Lotus Elise: 2bular decat\GT3 exhaust,HID's,turn signal&rear fins delete, CFside scoops, CFbinnacle,CFcenter console,Zoom CF mirror,APR Aero kit,CF 5-elem. diffuser,Exige mesh,Ohlins DA,RTD brace,RAC 'lites,Toyo R888's,HawkHT10's,CO painted calipers,SS lines,Reverie XC CF seat,Reverie CF steering wheel,Schroth Profi II 6 pt harness,shifter re-Enforcer,Manly mounts, Accusump,Moroso pan,BWR key to BWR S/C!
Spec Racer Ford #237
