surfer -
What a weird problem you have! From your complete description it almost sounds like the caliper bodies themselves are distorting from the pressure. You're definitely going to have to jack up the car and pull a wheel, then sit down by the caliper and inspect it as an assistant induces the noise with the brake pedal.
xtn
