Old 06-17-2009, 01:33 PM   #10 (permalink)
D Britt
SE Georgia
D Britt's Avatar
The number of balance weights may be a little deceiving. When you look at it in person, it looks like S111 put some weights in a row and then moved them over a bit. However, they left some of the adhesive where the weights were moved from. So you are seeing some of the old adhesive that looks like weights. Plus, I had S111 install a TPMS in each wheel.
Originally Posted by TimMullen View Post
If you drive in frontwards, then you have the "bump stop" backwards...
I didn't know there was a front or back. The bump stop has one hump in the front and one hump in the back, so the tire rests in the valley. This may not be totally clear from the picture. I drive in the garage forwards with the bumpstop under the front left tire.
I'll shoot some more pics of the whole car later this week. I still have to get the rear tires mounted on their rims since I am re-using my existing Yokohamas (which still have considerable tread left).
Last edited by D Britt : 06-18-2009 at 05:02 AM. Reason: Forgot about TPMS sensors... duh
D Britt is offline   Reply With Quote
