Old 06-18-2009, 09:23 AM   #227 (permalink)
robains
2007 Exige S
robains's Avatar
Originally Posted by Maypo View Post
Phil,
After complete installation (Editor, software and firmware) I don't have that checksum value. It's 73... I can see the new VVT table and the car seems to pull stronger at low revs (dyno session slated for tomorrow), but no 364FH checksum.
That's an old checksum, should read 7B6H. The latest nEditor is actually 7.1.12 if you use Phil's "package" download (.zip).
If you are installing Phil's zip, ignore the _MACOSX file warning (hit skip). I'd also recommend you backup your maps/data and control.def file. Uninstall the older software, then install the new software.
Rob.
