Old 06-19-2009, 03:55 PM   #7 (permalink)
elise/europa
The reason for having drive by cable... For sure it is not rational. I had trouble in the past with limp mode (with the Reflash set-up, but the reflash was not the cause).
Since I want to stick many years again with my car, I decided to minimise all electronic module. The DBW set-up is designed to meet pollution control, and to suit many device like stability control, traction control and bla bla bla. In case of trouble, a DBW throttle body is very expensive too. Drive by cable is more easy to diagnostic in case of trouble.
Other good thing with the drive by cable is: it is more easy to have a set-up to adjust the gas pedal relative to the brake pedal for the heel (how we spell that, I am french) and toe. Also, when I am working into the engine, I don't need to go inside the car to open the throttle body.
But it is few bad things: More sticky pedal feel; more pedal travel; very expensive switch over (engine hardness is just too much expensive).
For sure, it is rational at all. An Elise is not rational too!
Elise 2006, white, Katana
Europa 1969, green, H22A, 194 whp, 1550#
CONFIGTECH.ca / Solidworks
elise/europa is offline   Reply With Quote
