Originally Posted by robains
That's an old checksum, should read 7B6H. The latest nEditor is actually 7.1.12 if you use Phil's "package" download (.zip).
If you are installing Phil's zip, ignore the _MACOSX file warning (hit skip). I'd also recommend you backup your maps/data and control.def file. Uninstall the older software, then install the new software.
Rob.
Question, I'm running 7.1.11 with the firmware version of 7b6h. Should I go ahead and upgrade to 7.1.12? Should I also be using the control file that installs with 7.1.12? I'm not quite sure how the file versions match up. Kris had me just replace my neditor and control file to get me upgraded to 7.1.11 previously.
Thanks!
