Old 06-22-2009, 07:09 AM   #11 (permalink)
xtn
McLareghini Bugatterrari
xtn's Avatar
Originally Posted by Doghouse View Post
When a car has a 39% (front) - 61% (rear) weight distribution and is rear wheel drive it is likely to understeer.
Hmmmm... I'd like to point out that there are many, many factors that add up to under steer. Weight distribution is only one of them. I'd also like to point out that moving the CG farther back can inherently reduce under steer - depending on all those other factors of course - not inherently increase it.
xtn
