Originally Posted by saudio
Thanks. Very helpful.
So the same fluid can be both DOT3 and DOT4. That's interesting.
The only real difference between DOT 3 and DOT 4 brake fluid is the boiling point. All brake fluids must meet FMVSS116 minimum boiling points specification. DOT 4 is also less hygroscopic (less affinity for moisture).
FWIW, DOT 3 boiling point is 401 degrees F. DOT 4 is 446 degrees F.
Regards,
Wayne
_______________________
