Old 06-23-2009, 07:16 AM   #48 (permalink)
Tyger
burning bright!
Tyger's Avatar
Originally Posted by D Britt View Post
The CDL is not directly underneath the A/C, only partially. At least it was on mine. IIRC, this is why I could not get to the other screw on the other side of the module. Unless you have really tiny hands, I would definitely not worry about removing the old module and simply unplug the harness.
Thanks for all the good info. I am going to go in through light switch panel, try to pull some foam, and see what I see. If the CDL unit is below and slightly right of the air duct (my impression, from your description), I should be able to see it from underneath. How hard was it to remove the harness? Did it just unplug, or were there clips, etc.? I know it won't be possible to get more than one hand in there so doing anything tricky is going to be tough.
