I got a 12v bench-top power supply and a voltmeter (lost my other one) in from Amazon today.
I've tested that the Shift-I 'boots up' when attached to the power supply so I know I'll be able to get the voltages and such that are needed to make this happen. Straight off the power supply, it simply runs the battery test mode and stays lit, so it's perfect for pulling numbers.
It does suck that the LEDs are surface-mounted but I'm sure we can get around that. I'll have to look around for the most elegant solution.
I got the new instrument cowling in, as well, so I have everything I need to try to make this a reality.
I'll have some time to work on it this weekend and I'll keep you guys updated.
