Old 06-26-2009, 08:15 AM   #30 (permalink)
Demonized
NOT ßANNED!
Demonized's Avatar
Originally Posted by Thomasio
Can you guys post before & after photos?
I'll see if I can get some up later today
Originally Posted by kmt63 View Post
so how was the install for you?are the reverie scoops wider than stock?im happy to hear you got them on without instructions.that upper mount can be a bit of a pain.once you do it a few times its not bad.
Sort of a pain in the arse...
Yeah the Reverie are wider, and no two are made the same, making it a little difficult. What I did with the upper mount was take one of the bolts out, slide the tab through the opening (which was long side to side, upper bracket was long front to back) and tighten the one bolt as the tab spun around and touched against the inside of the body, enough to brace it to tighten.
Hope any of that made sense.
