Originally Posted by Boothy
I have just had an Ally heat shield made in 1.5mm thick, should be more than enough to stop radiant heat and does not weigh to much ;-)
cheers
Boothy
That's probably about ideal... yours is probably rigid enough not to buzz at certain RPM's. Hopefully you have the motor mount inserts so that your engine doesn't flop around too much.
