Originally Posted by Thomasio
That's probably about ideal... yours is probably rigid enough not to buzz at certain RPM's. Hopefully you have the motor mount inserts so that your engine doesn't flop around too much.
Mine is very similar to EricH's in design,however my 45deg is at the rear to deflect heat from the supercharger, I stopped the leading edge just past the intercooler so I can still get to the oil filler with ease. Its also slightly wider by the looks of it, 580mm to be exact
Its great to see lots of minds coming up with similar ideas, shame things are so quiet this side of the pond.
Boothy
