Originally Posted by cd4age
Hopefully someone knows the answer but I've just finished a compustar install but am stuck on the last wire which is for the remote start function. I have a negative pulse wire that needs to go to the starter relay but can't seem to find it. I tried going to the started button but both sides there seem to be hot so it looks like it just acts as a break. Does anyone know where I can find a ground seeking trigger line?
Thanks in advanced for any advice!
the starter relay is positive trigger... (can be found at immobilizar pin 12 also at the multifunction relay pack). if you need to have a negative trigger then you need to add a 30 A SPDT relay to convert it...
