Originally Posted by Westrock
This will make it more clear. Note the nut on the end.
(Just uploaded, give it a little time to process)
Maybe I'm confused then....
On the MP62 that came with the Katana kit there is a "keyhole" in the pulley, that fits on a little notch on the nose...
Your pulley appears to be on rather loosely, is this intentional? or did you manage to loosen the bolt a bit, which created some play in the pulley?
if not.... that might be your rattle right there.
Edit; I just re-read everything you wrote above, apparently I'm dumb... I have no idea how in the world you would get that off...
but that's probably your rattle :P
Hope it was the pulley that got stripped, not the SC housing.
