Old 06-29-2009, 04:35 PM   #102 (permalink)
turbophil
Plug Whisperer
turbophil's Avatar
Images: 6
Originally Posted by Dragon View Post
You sure you wouldn't want to put the fly wheel in the freezer (so it will shrink...) Heating it up will cause it to expand and fit even tighther...
Pretty sure... I believe in this case the hole would expand "out word", as the whole part would grow... Freeze the crank and heat the flywheel.... kinda hard to freeze the crank though
The webbing on the flywheel is big enough that it might expand inward, but it wouldn't in a traditional sense of press fitting something on... Would think it would be just like pressing a bearing into an engine case, i.e. heat the case and freeze the bearing...In any event, I always use the bolts to suck 'em on to the crank
Later buddy,
Phil
